Burning rubber smell
Old Feb 3, 2021 | 12:25 PM
kwald's Avatar
Default Burning rubber smell
I have a 2000 Mitsubishi Montero Sport 3.5L 6cy. I just changed all the belts and put new tensioner pulley in, why am I smelling burning rubber?
Old Feb 3, 2021 | 04:55 PM
Naeos_Valkarian's Avatar
I had this exact problem, it turned out I had accidentally tightened the belts too much. Assuming there is no squealing noises, tension on the belts is likely too tight.
EDIT:
mbwall45 made me think, there doesn't necessarily have to be a squeal for it to be loose.
The way I was taught to check the tension is by finding the longest run of the belt between two pullies and checking the deflection(or slack). Place your finger underneath the belt, right in the middle of the longest run, and lift up on it, the belt shouldn't move more than 3/4" but you also don't want it so tight that the belt hardly moves. Also check your tensioner pullies, if one of them is not tightened down flush with the tensioner body it will put the pulley at an angle which can lead to both the pulley getting worn out prematurely(or falling off because the nut isn't set right and may work itself loose) and the belt having improper tension/angle on it.
Old Feb 3, 2021 | 05:39 PM
mbwall45's Avatar
Might be because belt is made of rubber? which you said is new installed Would like to check if the tensioner / serpentine belt isn't tight enough? Is there a minimal smoke?
Old Feb 4, 2021 | 12:40 AM
Good advice on belt tension. You don't want to overtighten the belts. Rubber is one of those funky materials that tend to shrink when it warms up. So, if you start with overtightened belt - it will be even tighter once it gets hot. One other thing to check is pulley alignment. If they are misalligned, belt will flex more, rub (smell) and wear out faster
Old Feb 4, 2021 | 12:42 AM
Older Mitsubishi Sport engines had several V-belts.
JohnnyOutlander45
Apr 28, 2016 10:51 AM
FloodCityGirl
Feb 24, 2015 01:17 AM
stangmac8183
Mar 30, 2013 10:10 AM
jm99216
Feb 12, 2013 07:12 PM
jcdac
Jan 10, 2009 06:45 PM
