Buying 2001 Montero Ltd Advice
Old Feb 22, 2018 | 08:17 AM
russoaks's Avatar
Default Buying 2001 Montero Ltd Advice
Please help with advice - I've found a 01 ltd. 164k on the miles, in pretty good shape - pristine interior, starts up well but you have to give it some pedal a little initially, to keep it from feeling like it's gonna die - no biggie there tho, obvious a little tuning is needed.... Body and exterior is fine for this age vehicle - transmission and 4wd functions correctly, for 3600.00. It drives straight and brakes straight - no pulling to either side and no "extra" engine noises.
The main problem is - nothing in the center console works - so I can't test A/C, heat, sunroof, stereo and anything else in the center console area due to electrical issue. It seems like one big fuse needs to be replaced and that would be that. I wish it were that simple but I expect it to be a deeper issue. Oh and the fog lights wouldn't come on but all other lights work.
Any advice you guys can help me with would be appreciated. I'm probably going to get this either way, I'm already hooked.
Old Feb 22, 2018 | 09:21 AM
russoaks's Avatar
Default Probably Found My Issue - Thanks
I'll most likely need to check my electrical connections - which is fine by me, and clean the throttle body.
bmerz
Feb 24, 2021 06:55 PM
SpyderMR
Sep 27, 2013 06:24 AM
lovinmrv
Apr 9, 2009 12:43 AM
GregC
Apr 3, 2007 12:20 PM
FalconNDsun
Aug 26, 2006 11:28 AM
