Cig lighter power
Old Mar 11, 2012 | 11:19 AM
7-UP BILL's Avatar
Default Cig lighter power
I put this in interior wiring and got 0 responses. Has anybody "hot wired" the cig lighter to work all the time. Charging phone and using GPS is a pain when you shut down.
Old Mar 11, 2012 | 08:46 PM
Mr. Z.'s Avatar
I haven't rewired the cig. lighter power source, but I did wire up some lights so that they work whenever desired.
In the fuse box under the hood there is at least one aux. fuse, this will provide power with/without 'key'. Run your wire from this point to the cig. lighter. I'd run this with an in-line fuse as extra protection. My brother did this same thing you're looking into in his Toyota, and he even installed a separate switch for the power supply inside the center console. Think about how many amps you will be pulling when you purchase fuses and wire size.
Old Mar 12, 2012 | 09:22 AM
jrmdir's Avatar
You probably already were thinking this but just in case..........If you do run a separate wire from the fuse panel to the socket make sure you remove the original power wire from the socket - don't tie the two wires togther - or everything else on the ACC circuit you don't want will be powered all the time. Tape over the end of the original wire and secure it away from any metal surfaces. I also agree with adding a separate in-line fuse - there is no such thing as being too careful when running always-on hot wires through your truck. Place the in-line fuse as close to the power source as possible so that the entire length of the new wire is protected.
Ron
Old Mar 13, 2012 | 06:26 PM
7-UP BILL's Avatar
Great info, That's what I had in mind, but needed verifcation. Thanks
Old Mar 14, 2012 | 06:30 AM
jsk710's Avatar
Default Cig lighter Socket
Hi Guys
Just wire a complete new socket direct from the battery via a 10amp fuse link
This will give you power to charge your mobile when ignition is switched off
there is usually plenty of room thro the firewall somewhere to get wires thro ok
Regards
Keith
7-UP BILL
Mar 11, 2012 11:00 AM
klas
Oct 11, 2007 07:36 AM
TDAWG
14
May 16, 2006 12:01 AM
pauljdodson
Aug 7, 2005 02:17 PM
Flipz
Jan 6, 2005 05:11 AM
