Anyone know what this is for!!!!!
Old Jan 17, 2012 | 05:20 PM
Clayj73's Avatar
Default Anyone know what this is for!!!!!
I have a 2000 MS LS 3L ok on the black air intake hose from the air box to the throttle body. after the Map sensor close to the throttle body there is a male tube fitting coming out and on the passanger side valve cover there is another male tube fitting. I guess there should be a vacuum tube hook up between these?? its never had one since I've owned it but wondering why someone would have removed it. or if I'm wrong totally on what the tube fittings are for??? Please anyone
It has not caused a CES light in over 12,000 but wondering thanks
Old Mar 13, 2012 | 06:43 PM
Toofpik's Avatar
I think it helps Positive Crankcase Ventilation (PCV) but I'm not sure... Either way I would cover it up cuz ur gonna get debris in ur engine...
Old Mar 14, 2012 | 07:30 PM
Mr. Z.'s Avatar
Have you tried referencing a FSM?
Even a Chilton manuel will have what you need, if you don't use a web-based FSM.
anders_98
Aug 27, 2010 05:54 PM
RCJr9186
Dec 14, 2007 08:51 PM
speedform
Apr 1, 2005 07:47 PM
2.slow
Aug 25, 2004 02:10 AM
