Need help with half shafts
Old Mar 14, 2012 | 07:27 PM
troyford417's Avatar
Default Need help with half shafts
Hello, new to forum. I have a 2000 motero sport 4x4 3.0L. I bought it used and noticed it had a lot of problems. First, the passenger side half shaft was missing. was told it was vibrating so the original owner had it removed to solve the problem. I ordered reman shaft and also ordered shims and split ring for installing on outside of hub. I am going to replace bearings because they are rusty and probably full of road grim. Does anybody have a video or maybe some instructions on how to do this? do you have to remove ball joints or can you just slip it in since the passenger side bolts on the diff. side?
Thanks for any help
Troy
Old Mar 14, 2012 | 07:44 PM
Mr. Z.'s Avatar
If you are looking for a manuel for your rig, here's a link to some reasonably priced paper versions.
Mitsubishi Montero Manuals at Books4Cars.com
The third one down from the top looks like it has the 3.0 engine.
dave284
Feb 25, 2008 09:30 AM
hatchetman9449
Jan 28, 2007 07:53 PM
fbmange1ofdeath
May 8, 2006 08:50 PM
petro4411
Jan 29, 2006 10:45 PM
zero
Jan 13, 2006 10:34 PM
