Cold idle to high
Old May 1, 2014 | 12:50 PM
2001Mitch3.5XS's Avatar
Default Cold idle to high
Hello guys n tks. For all ur help here. However I have a question for yas. When I start up my motor races up to 2000 RPM. Then when it gets warm it goes back to normal. Tks.
Mitsubishi montero sport XS 3.5 2001.
Old May 1, 2014 | 01:04 PM
Akzle's Avatar
in my day it would have been a reed sticking.
Probably a sensor. Iac, maf, thermo...
Old May 1, 2014 | 11:08 PM
Default Vacuum leak?
Check little vacuum hoses around the top of the engine (by intake manifold). A cracked vacuum hose could be a culprit.
Old May 2, 2014 | 08:46 AM
Thumbs down I will try the vacuum hoses n let ya know
Thanks for all your help in this matter. I did check out the vacuum hoses and to my surprise they are all still good...no cracked or damaged hoses.
Old May 4, 2014 | 09:02 AM
Default Ok so here we go on the COLD high idle!!!!
Ok, I have the question into yahoo Q&A and will keep yas posted.
OK... Here we go again... I should have posted this also but just forgot...
I noticed the Montero getting slightly louder, then the idle started to get higher and higher ...
Now it's at about 2300 RPMs only when cold then warms up after a few minutes and goes right back to normal. I took apart/cleaned all the sensors, checked out all the vacuum hoses ( all good ) I have 125,000 miles on my baby now. I was waiting to do a tuneup on it cause if you look for trouble YOU WILL ALWAYS FIND IT. LOL. Now keep in mind I change the oil every 3000 mi. or before any trips and it is very well maintained too. Thanks for your time here as this is still a very big help for me.
Old May 5, 2014 | 01:20 PM
UPDATE...I GOT THE FIX WITH BEAUTIFUL PICTURES UNFORTUNATELY THE FORUM WILL NOT LET ME POST FROM MY DESKTOP SO NO PIC'S HERE BUT YOU CAN EMAIL ME AT... handson59842@yahoo.com and I will send them to you.
Now I had 2 bolts that rusted almost all the way off of the catalytic converter so I removed the rest and put some bolts through and tightened them up with no leaks now. It was right by the oxy sensor so I guess that was the culprit that was giving me a false reading. Once again my Montero runs fantastic.
I would still like to thank AKZLE and HUNTERD for your help in this matter.
Old May 6, 2014 | 06:53 AM
I wish I knew how to put the pix in here...
Old May 6, 2014 | 06:56 AM
URL of the image ... what ever happened to the simple drop n drag or getting it from my C drive...what gives. Why complicate something when ya don't have to or am I missing something here.
wilde
11
Sep 29, 2015 11:33 PM
jms
Sep 30, 2012 02:23 AM
Raquel
Mar 26, 2011 11:03 AM
Pribs
Mar 28, 2008 02:46 AM
yamahablaster8230
Aug 29, 2006 09:28 AM
