coolant leak rear right head 2002 , 3.0 L
Old Aug 28, 2014 | 09:15 AM
Paul Russo's Avatar
Default coolant leak rear right head 2002 , 3.0 L
Hello Folks , Heres the story thus far , Found coolant leak , Thought I was going to be lucky an it was just a Throttle Body Coolant Hose -- NOT !!!!---- tracked it down , Back of Right Head , there is a small metal tube thats leaking coolant . Does this tube connect to the Pipe in the center of V - valley of Engine going to water pump ????? If so can you remove this with out taking off Water Pump ??? Thank You .
Old Aug 29, 2014 | 01:22 AM
Hi Paul,
If our coolant leak is in the back, it is probably coming form a coolant passage that connects two halves of the engine. It bolts to the back of the left and right head. There is a replaceable gasket between the coolant passage way and the head. If your leak is from the little "T" in the center of this passage, then it is likely the hose that leads the the cabin heater. It is not the water pump connector, the pump on Monty is in the front part of the engine by the timing belt. You should be able to get to those parts in the back if the engine is cold and you have small hands.
KevGTZ
Aug 12, 2013 03:04 AM
Huaje
Jul 4, 2011 12:48 AM
Huaje
Jul 4, 2011 12:46 AM
ruski
Dec 30, 2010 05:32 PM
novetek
Feb 20, 2006 04:16 PM
