ecu idle reset/relearn HELP!!!!!
Old Aug 11, 2015 | 01:33 AM
99mk2's Avatar
Default ecu idle reset/relearn HELP!!!!!
how do i reset my computer when i unplugged my battery now the idle is crap like 300rpm i read that you have to let it idle but ive done that and nothing yet any advice? any instructions?
Old Aug 11, 2015 | 02:02 AM
99mk2's Avatar
Originally Posted by jhill15
As far as your idle, my bet is that it needs to be relearned. Every time you unhook your battery you have to go through an idle relearn procedure. ..its really annoying and I have never owned another vehicle that needed the idle to be relearned when the battery is unhooked. So do this and see if it still wants to die out on you afterwards.
Relearn procedure
"Make sure that all accessories are turned off, a.c. radio, lights etc.."
That is very important as the bcm will learn the wrong idle speed and you will find yourself in the same position.
1. Unhook the battery for a few minutes and then hook back up
2. From a cold start. Turn the ignition to the acc position for 20 seconds and then turn back off.
3.start the engine with no accessories on and let the engine idle from cold to normal temp for 15 minutes.
4. Shut the engine off.
5. Turn the ignition to the acc position and then back off.
6. Start the engine and let it idle in park for 3 minutes.
7. While engine is still running hold in brake and put it in drive. With brakes pressed it the engine idle in drive for 3 minutes.
8. Put the car back in park and shut off for 20 seconds.
9. Start the engine.
10. Finished
Pretty annoying huh?
That should take care of your idle and if not then a further problem exists.
Hope this helps.
Post back and let me know if it worked
Cheers
ok so i found it search is a nifty little thing (0 before anyone else says it.)
Old Aug 11, 2015 | 09:02 AM
Guyfromhe's Avatar
Never heard of/seen a car that does this either :P and I see a lot of dead batteries here in the frigid north.
Old Aug 12, 2015 | 01:24 AM
99mk2's Avatar
my buddy drives a ranger and he said they have a simular thing for resetting there ecu. might have been his old ranger. but yeah dont know why they wouldnt have it built in to the system.
Old Nov 24, 2019 | 07:56 PM
Buster1's Avatar
I have a similar issue with my 2003 Montero Limited.
All things pointed to a defective idle valve?
Picked one up at the auto parts house
and they must have given me one for a Sport
for it looks nothing like mine.
Only acts up once the vehicle has warmed
to normal temps.
Could your problem be the IAC?
user 27474884
Aug 28, 2022 03:45 PM
codeaholic
Nov 1, 2016 07:47 PM
nyc95gst
Jan 18, 2008 01:25 PM
Dookitchen
Oct 10, 2006 10:54 AM
tkalligo
Jan 21, 2005 03:05 PM
