idle relearn procedure
Old May 26, 2014 | 01:57 PM
user 27474884's Avatar
Default idle relearn procedure
Un hooked my battery now my idle sucks, can someone tell me exactly how the procedure goes to relearn correct idle?
Old May 27, 2014 | 06:25 AM
Garifini's Avatar
On my 95 LS I let it idle for five minutes, then drove it for the same, over the next day it figures itself out, I have not had to use the official method, with the special tool. Have to let it run for a bit, if you simply turn it off it'll stay the same.
Old May 27, 2014 | 04:16 PM
Thanks a bunch man, I will unhooked my battery again and try that.
cheers!
Old May 30, 2014 | 10:50 PM
quechon's Avatar
i didnt wanna create another threat since this one is already talking about idling
i wanted to ask what is your idling when montero has fully stopped in park (P) and in drive (D) thanks in advance
Old May 31, 2014 | 06:12 AM
At first i would go around a turn and hit the brakes and it would die. Unhooked my battery, turn on ignition for 10 seconds then turn off. cold start let it warm up to normal temp for 15 minutes. Turn it off then back on. Idle in park for 3 minutes then with the brake on idle in drive for 3 minutes. All of that and still in drive when slowing down it woul drop to under 500rpm. I drove it for a couple days and It has worked itself out. Now it idled around 1000rpm.
Old Aug 28, 2022 | 03:45 PM
Buster1's Avatar
Default Throttle Body issues
I replaced my throttle body with aftermarket one from China. The dealer wanted around $1100.00 O’Reiley’s wanted just about the same.
I paid $240 including shipping.
Installed it and it immediately worked fine. Then the Montero set for about 6 months. Now when I turn the vehicle on, it begins its idle very high. (15-
1800 rpm’s. It won’t accelerate past 3000 rpm’s
Once the vehicle is warm then I can unplug the pigtail to the TB , shut the truck off and Re plug the pigtail into the TB
Turn the vehicle back on it runs perfect.
My question is this. Do you have to use a scanner to relearn the throttle body?
Maybe the cheaper throttle body is the problem?
Anyone else have this experience?
99mk2
Nov 24, 2019 07:56 PM
codeaholic
Nov 1, 2016 07:47 PM
lars
1st Generation
Jan 18, 2014 12:04 PM
n5926g
Nov 26, 2006 01:10 AM
galanturd
Mar 24, 2005 02:52 AM
