Electronic brake wiring from factory?
Old Apr 27, 2020 | 11:12 AM
s6w's Avatar
s6w
Default Electronic brake wiring from factory?
Hey all,
Aside from having it checked (no idea what to look for) is there a way to see if my 2003 Montero Sport came with electronic trailer brake wiring from the factory? Maybe VIN or something?
It did not come with a tow package. I had a hitch added a few months ago.
Thanks!
Old Apr 27, 2020 | 08:04 PM
Usually trailer brake is not wired. You have to add controller for it.
Old Apr 27, 2020 | 08:06 PM
s6w's Avatar
s6w
Dang, was hoping they had the wire run from the factory in some models so all I’d need is the controller. Thanks!
Old Apr 27, 2020 | 11:39 PM
I'm only aware of those factory wiring harnesses on full size pickups. It shouldn't bee to hard to wire it in. Carefully read the manual for whatever controller you got. I think you only need battery positive feed, ground and brake switch signal (perhaps a modulated signal?). Then one wire will run back to the trailer connector.
Monseensusan
Mar 14, 2020 05:51 PM
Spiderman3k
Sep 9, 2018 10:58 AM
strictlyvrt
Apr 13, 2008 12:29 AM
cooljw
Feb 26, 2008 06:28 PM
