Engine to Heater Matrix Connections
Old Mar 26, 2018 | 05:19 PM
ddudman's Avatar
Default Engine to Heater Matrix Connections
I have a 1999 Mitsubishi Montero that's had cooling system issues recently so I decided to tear her down and replace any parts that looked worn or leaky. In the (long) process of (finding and then) replacing the coolant crossover and coolant inlet pipes I've lost my diagram showing how I reconnect those to the heater matrix. Does anyone have a diagram and or photo they can share? I've attached a picture to this post with the four ports identified (A, B, X and Y). As I recall A went to Y and B went to X, as in the pipes crossed over, but I want to be sure.
BTW - The two new pipes I purchased are color coded (I think). The longer pipe has a yellow dot on the heater matrix end, while the shorter pipe has a white dot.
Thanks
Attached Thumbnails Engine to Heater Matrix Connections-montero-heater-pipes-1-edit-.jpg   Engine to Heater Matrix Connections-montero-heater-pipes-3.jpg
Edward Moore
Mar 15, 2017 03:08 PM
osushinobu
Jul 26, 2007 12:53 AM
p4c0
Feb 22, 2007 06:36 PM
04scooby
Feb 10, 2006 04:02 AM
ricers_rule
Jan 8, 2004 03:48 AM
