Engine to Heater Matrix Connections
I have a 1999 Mitsubishi Montero that's had cooling system issues recently so I decided to tear her down and replace any parts that looked worn or leaky. In the (long) process of (finding and then) replacing the coolant crossover and coolant inlet pipes I've lost my diagram showing how I reconnect those to the heater matrix. Does anyone have a diagram and or photo they can share? I've attached a picture to this post with the four ports identified (A, B, X and Y). As I recall A went to Y and B went to X, as in the pipes crossed over, but I want to be sure.
BTW - The two new pipes I purchased are color coded (I think). The longer pipe has a yellow dot on the heater matrix end, while the shorter pipe has a white dot.
Thanks
Thanks
Edward Moore
Mar 15, 2017 03:08 PM
p4c0
Feb 22, 2007 06:36 PM
