Flickering lights Montero Sport 2000-2004
Old Nov 18, 2014 | 11:59 AM
MrGalantGuy's Avatar
Default Flickering lights Montero Sport 2000-2004
I just purchased a 2001 Montero sport but prior I looked at and test drove close to a dozen of them as i was shopping for one. I noticed 3 Montero Sports including the one I bought all the lights flicker at a steady frequency. The one I bought has a minor flicker but noticable especially at idle seems to be dependent of RPM. The others seems to flicker at a constant frequency at any RPM range.
First thing comes to mind might be a alternator issue but wondering if this is a common problem on Montero Sports since I have experienced this on 3 of them. I have done research which no real answer...most common is probably a alternator issue, some of said its a ground issues, fuse issue or even the light/signal which on the column.
I have had vehicles with alternator issues..but never experienced ones with flickering light symptoms.
Old Nov 24, 2014 | 11:40 AM
Montybishi's Avatar
I have a similar problem and I also noticed that when this happens the belt tensioner is moving/bouncing quite a bit. I replaced the Alternator and the 100amps fuse and it fix the flickering issues and it's all good now.
Mitsiboy
Oct 23, 2016 06:15 AM
Brian Yazzie
Jan 23, 2012 09:49 PM
GAngeldb
May 27, 2009 01:59 PM
Mr Grier
Jan 2, 2009 10:35 AM
Sup3rs
Oct 2, 2008 09:10 PM
