Fuel pressures
Old Dec 4, 2021 | 01:30 AM
ghostrider20's Avatar
Default Fuel pressures
Hello. I知 working on a 2000 Montero Sport for an older veteran. I知 a GM/Chevy guy so seeking some knowledge before trouble shooting. I知 helping him out, and there is a budget. The vehicle has 217K Miles, and runs good, no codes.
Issue when starting cold, is long cranking. It always fires and runs, but I feel as though it should fire quicker. My guess is fuel. I haven稚 put a fuel pressure gauge in it yet as I would like to know what I知 looking for when I do. I assume when key is turned to ON, the fuel pump should prime, then shut off, based on a time relay or rail pressure. Question, what is the priming method, and if not priming where to look. Second, what fuel pressures are normal?
Old Dec 4, 2021 | 10:38 AM
On a full sized Montero, fuel pressure at idle should be around 38 PSI. With vacuum hose on fuel pressure regulator, pressure should go up to 50 PSI when revving up engine. I would think Montero Sport values will be in the same neighborhood. As far as pressure drop after engine off - there should not be significant drop down withing two minutes after turning off engine. If you do observe significant pressure drop, figure out which end of fuel supply system is leaking (supply or return) by pinching off those hoses after engine is turned off and watching the pressure change. This will indicate which way fuel is bleeding off and where the problem may be. Generally speaking is pressure drops off gradually, its ether a leaky fuel injector or fuel pressure regulator. If pressure drops rapidly immediately after engine shut off, you likely have a stuck check valve in the fuel pump.
Old Dec 4, 2021 | 02:52 PM
Thanks for the info. I’ll report back when I get a gauge on it.
Old Dec 7, 2021 | 02:17 PM
Ok, back home and working in Montero. I have no idea where the Schrader valve for the fuel rail is? Is there one? If so, is it the same as GM/Ford etc?
Old Dec 7, 2021 | 09:18 PM
Montero (Mitsubishi in general) does not have one built into the system. You have to have an adapter that fits between high pressure line and fuel injector rail.
Old Dec 7, 2021 | 11:23 PM
Thank you. I have no idea how old the fuel filter is, so going to replace that. When I have that off, I値l hook up to the line and read it from there.
Being such a common diagnostic procedure, I find it odd there is no service port to hook up to.
Old Dec 8, 2021 | 08:40 AM
I think it's a testament to Mitsubishi engineers confidence in their work 😄
kevinclarkwy
Oct 26, 2017 08:26 PM
mount
Sep 23, 2015 11:16 AM
Toddo
Dec 4, 2013 04:56 PM
triphex
Aug 31, 2013 11:23 AM
BC31059
Aug 15, 2007 06:12 PM
