fuel pump
Old Mar 1, 2011 | 10:18 AM
rich lapham's Avatar
Default fuel pump
i dont have any power to fuel pump anyone have any help
Old Mar 1, 2011 | 12:29 PM
zoza1982's Avatar
Can post more details?
Did you make sure that you it is a fuel pump? How many miles car have, and do you have a knowledge that car had the fuel pump ever replaced?
Did you check the fuel pressure?
Get a help from someone, to turn on/off ignition few times while you lean your ear on the opened gas tank and you should hear a noises when the keys turns to on position. If its silence ...its dead.
Do u get any power inside of a vehicle when you turn the the key to on position?
Old Mar 2, 2011 | 05:08 AM
Default fuel pump
i took the covers off and got to the sending unit and checked the plug going in i also checked the fuses in the box aswell as under hood
Old Mar 2, 2011 | 05:11 AM
by the way im new to this site and want to thank you for your help
Old Mar 2, 2011 | 10:21 AM
zoza1982's Avatar
Post here your year and model and I will post here service manual how to replace it if you want that.
Let me know.
Old Mar 3, 2011 | 05:01 AM
2002 montero ls i found were the pump is i cant find the fuel relays for it i have no power to the pump as far as i can tellthanks for the help
Old Mar 3, 2011 | 09:41 AM
zoza1982's Avatar
Here is what I got for your model. I uploaded it to my rapidshare account. Since files are too big to be posted here.
Last one is "fuel pump replacement" applies to your vehicle too...its for mine.2001.LS.
Overview " relay is at the "Q" Location:
http://rapidshare.com/files/45076265...w_Location.pdf
Fuel_pump_relay "Q" location:
http://rapidshare.com/files/45076226...pump_relay.pdf
Testing the realy:
http://rapidshare.com/files/45076395..._the_relay.pdf
Fuel pump replacement:
http://rapidshare.com/files/450762257/fuel_pump.pdf
Last edited by zoza1982; Mar 3, 2011 at 09:42 AM. Reason: forgot to include explanation.
Old Mar 4, 2011 | 08:02 AM
hi zoza i want to thank yo for all the halp it was great im gonna try this
Old Mar 4, 2011 | 08:40 AM
zoza1982's Avatar
You are welcome.Glad that I can help.
Let me know if you need any other service manual.
Good luck!
MNalfa
17
May 9, 2019 06:07 AM
Germankat
Mar 19, 2008 05:28 PM
Germankat
Mar 19, 2008 06:43 AM
agallardo
Feb 22, 2007 03:46 AM
audionxs
Sep 19, 2003 11:56 PM
