Gen 3 Limited Power Antenna Motor replacement
Old Jun 16, 2017 | 06:16 PM
monty768's Avatar
Default Gen 3 Limited Power Antenna Motor replacement
Yes, I searched!
I am in the process of replacing my motor. I got the motor out but was surprised the antenna cable does not disconnect at the motor. Does it actually run all the way through the firewall to the back of the radio? Do I need to pull the radio to unplug and fish the cable of the new unit through?
And secondly. Are there any fixed unit assemblies that work here? I had a generic one from Autozone but because where the hole is cut on the Monty, it would stick at a really weird angle out pointing outwards. Really want to ditch the power motor and go fixed but can't find the right unit.
Old Jun 19, 2017 | 04:52 PM
I've extended my antennae and disconnected the motor wire. Now I have a "fixed" antennae. I think you are right, the black wire goes all the way through the firewall. It sucks, since it would be much easier to unbolt it from the motor than to remove the radio and fish the wire back to the radio after replacement. One thought:
anyone knows if it is possible to get a CAT wire splicer and just cut the wire near the motor and install the splicer to reconnect it?
tom61
Aug 6, 2016 10:50 AM
ddappete
Oct 19, 2013 02:04 PM
captchuck
Jul 12, 2010 08:25 PM
redturboeclipse
Oct 26, 2009 10:41 PM
mditt8671
Aug 17, 2009 12:02 PM
