Hatch won't Latch
I have a 2002 Montero Sport. The rear hatch door will not latch when I close it. This happened last year and shortly after I had to replace the battery. The hatch latch began working properly again with the new battery. Now it's happening again but the battery is still good. I oiled and greased the parts, so they are not rusted closed. Could it be an electrical problem or is it just coincidence that it stopped working when the battery went dead?
Thanks for your input.
Not that familiar with the Sport. Is there an electric latch release button in the driver's area? If not then it has to be a mechanical problem with the latch. If so, then it could be that the un-latch solenoid is stuck open or for some reason has constant voltage supplied - which could be a bad switch.
I know this is not much help. But look carefully at the latch-hook assy in the door and see if the hook is being held open permanently. You can use use a screwdriver or metal rod to push into the gap and see if it closes around the screwdriver (simulating what happens when it strikes the male catch in the car body. If it fails to snap around then work backward thru the linkage and/or solenoids to find out why.
Or it could be that the male catch in the car body has loosened and has moved out of the proper location to meet the latch opening.
Ron
Ron
Thanks for the info. There isn't a seperate switch to unlatch the hatch (liftgate). It unlocks with the remote key fob or with the unlock switch on the door that unlocks all the doors. I can move the part with a screwdriver so that it locks on the screwdriver. So, mechanically i can move it back and forth. The mateing piece is not out of place.
writersmark
Mar 2, 2014 09:29 AM
