Having problems with my transmission
Old Jan 12, 2007 | 08:30 PM
Pokerdude's Avatar
Default Having problems with my transmission
I have a 01 montero Sport LS, On thursday whenever I would slow down to take a turn or go around a curve and then accelerate to get my speed back up my truck would jerk a couple of times, But whenever I would come to a complete stop and goit would go good without jerking but this evening it started doing it from a complete stop and from slowing down and it is getting worse every time. I had the battery and alternator checked and they were fine. I am thinking that it may be the filter and fluid as it not been changed since 60,000 and it has almost 138,000 now. Any suggestions or ideas? Thanks in advance for any help.
Old Jan 13, 2007 | 01:47 AM
off roader's Avatar
Default RE: Having problems with my transmission
If it's you're tranny then it should happen in both situations not just turns.
I'd check other things first. Mitsu tranny's are pretty reliable and usually run more than 200K before needing rebuilds. Yours is getting older though I'd replace the fluid more frequently. It will lenghthen it's lifespan.
HTH.
Old Jan 14, 2007 | 05:31 PM
Pokerdude's Avatar
You were right off roader, not my tranny after all but the way it felt i would have sworn it was the transmission.The number one cylinder is mis firing and I need a tune up,A mechanic is one thing that I am not,Butthanks for your help.
bujlaky
Nov 29, 2013 07:07 AM
5Tizzle
Dec 29, 2006 04:54 AM
jake88
Oct 16, 2006 10:21 AM
tunit7
Jul 19, 2005 08:09 PM
shamsulaswad
Oct 31, 2004 07:44 PM
