Help needed
Old Dec 28, 2011 | 08:32 PM
sutty451's Avatar
Default Help needed
Hi Guys, first post on here, hope you can help.
I own a 2002 mits challenger 4wd (aka montero sport), which has a LPG gas conversion kit fitted. I was let down (very badly) by the mechanic I used and have since been loathe to entrust my pride and joy to another.
I recently changed the ignition leads (which was a pretty mamoth job for a novice....). I did have one or two minor hiccups but overall it went very well and almost everything is good.
I just have one problem...I have attached a pic with the problem areas identified, but in summary, can anyone tell me what the part is called that I have circled....and secondly, this part has a tube coming from the back of it (see arrow on pic)...where should this connect to. It was already disconnected when i started the work and I cant find where it should go to.
Any help much appreciated.
cheers.
Old Dec 28, 2011 | 09:18 PM
xteacher's Avatar
It's a vacuum actuator of some sort. Is it part of the throttle body? It appears as so. I can only assume it hooks up to a vacuum source. But I don't know which one. Is that a part of the LPG conversion kit?
Old Dec 28, 2011 | 09:31 PM
sutty451's Avatar
hi, thanks for the reply. its mounted on top of the throttle body...im not sure whether its part of the lpg kit or not...i have a feeling (based on other pics I have seen on this site) that its not.
The tube on it is fairly long (around 18inches) but im buggered if i can find anywhere that it might fit onto!!
My cruise control doesnt engage anymore and I did wonder if it was part of that set up...???
Old Dec 28, 2011 | 10:02 PM
xteacher's Avatar
Well I think you may have answered your own question. But you need to find where it plugs into.
steelviper102002
Jan 12, 2005 09:21 PM
rpatillo
Dec 28, 2004 09:10 PM
m3kgt_99
Sep 20, 2004 02:22 PM
daryl
Mar 9, 2004 01:43 AM
emroul
Jul 31, 2003 01:40 PM
