I think I need a new alternator
Old Jan 5, 2015 | 01:06 PM
_it___is_i's Avatar
Question I think I need a new alternator
Last night the brake, ABS, Battery, and Temp. lights came on. Sometimes they would turn back off when I hit the brakes. The display screen in the center of the dash flashed a warning 'irregular voltage,- system will shut down in 7 seconds' and shut itself off for a couple minutes and come back on. It repeated this several times before I got home. The vehicle functioned normally. The only possible odd thing was that possibly the head lights were brighter than normal. I was driving through a rain storm so it was hard to tell.
This morning I put a volt meter on the battery, which is only a few months old. Battery while not running was 11.3 which indicates to me it was drained during my drive home. When I first started it up it registered 14.5 - 15.5 and there were no warning lights on the dash. After a minute or two the warning lights came on and the voltage fell to 12.
Thats the only thing I had time to do. I looked at the fusible links next to the battery and they appeared fine.
I'm thinking the voltage regulator on the alternator is shot. What else should I check before I buy a new alternator?
Old Jan 5, 2015 | 09:20 PM
Akzle's Avatar
id say you got it in one.
Battery should rest at 12.2-12.8, charge at 13.8-14.8
Old Jan 5, 2015 | 11:40 PM
It does sound like a voltage regulator failed. Check to see if you can replace only the regulator instead of the whole alternator. Should be much less expensive
Old Jan 6, 2015 | 01:47 AM
_it___is_i's Avatar
Thanks!
Anyone know the amperage specs on an oem alternator? Mitsubishiparts.com doesn't list any details. They do sell the voltage regulator separately but it will only save me ~$40. Others listed on the net range from 80 amps to 150.
Old Jan 6, 2015 | 02:28 PM
_it___is_i's Avatar
It's 100 amps. Ordered a 100amp raylock with a 3 year warranty from NAPA. After core refund it will only be around $80 and will take longer to pick it up than it will to replace.
Old Jan 14, 2015 | 03:42 PM
mlduncan96's Avatar
Just thinking from other forums, could your failed alternator be caused by a leaking cam oil seal? Might want to check as it could easily ruin the next one.
Old Jan 15, 2015 | 01:29 AM
Good call. If you have oil leaking on top of the new alternator, your problems will be right back.
disneylove84
Mar 4, 2012 01:37 PM
lovinmrv
Jul 20, 2011 07:39 PM
dfrankjr
Apr 16, 2010 04:39 PM
bc92065
Aug 3, 2007 07:33 PM
bedjemp
May 19, 2005 02:02 PM
