junk in the pan
Old Feb 14, 2011 | 08:47 AM
2k1monterosport's Avatar
Unhappy junk in the pan
did a weekend job with my younger brother on my 2k1 montero sport 3.0, been hearing a weird noise and the oil light came on so i figured the oil pump wasnt working. after a slight mishap with the removal of the of the oil pan i took a look on the inside and found bits and bits of metals ranging in size, the largest being about an inch long. I also found a bolt maybe about 2 in long along with its nut...........I think i might have a bad piston....... has any one had this problem?
Old Feb 17, 2011 | 11:56 PM
SSfanatic's Avatar
Sorry man but it sounds like its time for a new motor. Probably won't know exactly what all the pieces are from until you pull the motor all the way apart.
Old Feb 18, 2011 | 12:45 AM
You spun a bearing.
New engine time.
Old Feb 18, 2011 | 01:17 AM
redturboeclipse's Avatar
rebuild/new engine time
Old Feb 18, 2011 | 05:42 AM
You should NOT rebuild that engine.
set
Sep 21, 2009 10:34 AM
2000zeroGT
Nov 19, 2008 02:54 PM
GSXPimp
Jan 22, 2007 06:18 PM
xobella
Jan 20, 2006 05:11 PM
mike96eclipseRS
Nov 2, 2004 09:15 PM
