Like Others Before...Timing Belt Change
I had to replace water pump and an AC compressor on a 99 Sport w/3.0V6. Car also has factory alarm horn. The car was running fine...till I started screwing around with it.
I opted to replace the timing belt as vehicle has 73k miles on it.
Work is completed and included botha cam position sensor and a crank sensor.
Problem is the starter spins but no engine start. All timing marks have been checked three times. However, if this thing had a distributor I could be sure all was at #1 TDC.
I haven't checked for spark at any of the three coil packs or six plugs yet. I do have fuel in the fuel return line but, do not smell raw gas at the tail pipe.
Questions:
How do you ensure a #1 TDC without a distributor?
Might there be some other electrical "control device" (perhaps within the alarm circuit) that wouldprohibit spark and fuel operation?
Thanks in advance.
Questions:
Thanks in advance.
you probably knocked the crankshaft reluctor off of the mounting pins on the back of the crankshaft gear, as long as you didnt bend any valves during the belt change.
PalmSprings
Nov 5, 2013 12:12 PM
monteroX99
11
Apr 6, 2011 10:29 PM
