maintenance ? new to me Montero Sport
New to these forums and now have a new to me 2002 Montero Sport ES, 2WD, automatic, 145k on the clock. No wrecks according to Car Fax. Very clean interior. Starts, runs and stops. Everything seems to work (lights, AC, heat, locks, mirrors, etc). Idle seems a little hight to me (roughly 1200rpm in P about 1 minute after start up), but it idles at around 600rpm while at a stoplight in D and it's been a while since I've owned a Mitsubishi. Doesn't seem to leak anything but's its been raining like crazy all day and I park it outside.
Just picked the truck up today, manuals are already ordered as nothing came with the rig. I'm the 3rd owner. Original owner had it for 15 years, but maintenance records are spotty past routine oil change info that I can dig up.
My initial thought, as I don't know the history, is to do the following in the coming days/weeks:
-tires (were not good, replaced them today)
-oil & filter - done today (shop says at some point during an earlier oil change a temporary plug was used in the oil pan - going to have to see if it can be tapped and replaced or find a replacement pan & plug)
-brake inspection/repair
-coolant flush
-tranny flush
-rear diff service
-plugs/belt/tune up
-timing belt
-fuel filter
-injector cleaning
Am I missing anything obvious at 145k with little history at my disposal? Once the manuals are here I'll put together a plan but it's been a while since I owned my '91 & '97 Monteros and am anxious to get started.
Thanks in advance for the thoughts/ideas.
-coolant flush
-tranny flush
-rear diff service
-plugs/belt/tune up
-timing belt
-fuel filter
-injector cleaning
I think you got all the main items that need to be addressed in your list. I would add REPLACE break fluid, since you don't know how old it is.
As far as transmission service - don't known what you mean by "FLUSH". If you are talking about "power" flushing transmission backwards to get to all nooks and crannies, as many shops recommend, I would not do that. Just change the transmission fluid according to Mitsubishi service guidelines. Also make sure to use Mitsubishi fluid for that, don't go with generic. Mitsubishi transmissions are notorious about not liking non-Mitsu fluids.
Thanks HunterD. You're right, the tranny "flush" as you describe it doesn't sound like a good idea. Thanks for the intel on the tranny fluid too. I'd read that on these boards (I think) and this was a great reminder. I imagine that a good non-dealer shop can get the Mitsubishi fluid? Can you recommend a good source, just in case?
I get mine at the local Mitsubishi dealership. I find that the cost of Mitsubishi trans fluid is pretty close to that of a reputable brands trans fluid, so you are not "loosing" any money going that route. You are avoiding doing transmission service twice, so you are actually saving money
LumaberJackJim
Mar 5, 2018 10:42 AM
BlackMont2016
Aug 23, 2017 11:28 PM
PSULionRP
Mar 8, 2013 01:34 PM
monteroX99
Feb 21, 2011 08:58 PM
newmonty
Jun 16, 2009 05:06 PM
