Mitsubishi montero sensor problem
My 1996 mitsubishi montero ls is showing the check engine light so I showed it to my reputed mechanic who is my friend and he diagnosed it and said that there is no problem with the car its just the sensor which triggers the check engine light is burned so it keeps the light on for no reason otherwise there is no problem with the car.He said that it is hard to replace beacause it is deep inside so for now just dive the car without worrying about anything.I guess that there were no codes stored too.The gas cap is tight.Can you help me figure out where those sensors could be in the car and how to replace it?Thanks.
Every sensor that is connected to your car can trigger the check engine light, there is no specific sensor for this. IE temp sensor, oil pressure sensor, throttle position sensor, oxygen sensor, ect. since your vehicle is OBD2 compliant, take it to autozone have them hook up a scan tool, then let us know what the code is and we will tell you how to fix it...
The Engine Control Module is responsible for turning the check engine light on and off, when it detects a problem from one of the many sensors, it illuminates the light and stores a code, from what I have read on the non-US model of that montero if the ECM fails the light will remain illuminated during diagnostics if the ECM itself has failed, otherwise it will flash a sequence code. Is your montero a US or non-US model?
If you are located near a autoparts store such as autozone, napa, ect. They will hook up a scan tool to your vehicle free of charge. Its always good to get a second opinion and that would be a good start. If you do this and they still show no stored codes with the light still being on, I will do a little more research for you to help diagnose your problem.
Kuban0
Mar 11, 2013 11:02 PM
