Montero 6G74 3.5 liter motor engine compatibility
Old May 28, 2016 | 10:17 AM
wilde's Avatar
Default Montero 6G74 3.5 liter motor engine compatibility
Are all the Montero Sports and full size Monteros with the 6G74 3.5L motors compatible to be swapped into any Montero that originally had a 3.5L motor?
I don't plan on buying any Sport models to drive because of preference, but they are everywhere it seems and usually have good motors in them when parted out. I have 2001 XLS and 2002 Limited models with 3.5L motors. Will any/all of the 3.5L Sport model motors swap into my full sized models?
A junk yard told me yes, but it was trying to sell me a motor, so I'm not sure if I trust the information.
Thanks for the clarification if you know!
Old Feb 12, 2018 | 01:05 PM
dahlelama's Avatar
Old thread but I'll answer it based upon my research... researching because I was about to do a 6G74 swap from a 2002 Montero Sport 3.5L into a Full size 2001 Montero 3.5L.
NO They are not all the same. The 2000-2003 6G74 found in the Full Size Montero was a version for the Montero only. Not for Montero Sport.
MITSUBISHI 6G74 2/2000-2003 ENGINE 6G74. SOHC. 24 VALVE.CAM AND CRANK SENSORS.
OIL FILTER MOUNTS TO OIL PUMP ON PASSENGER SIDE.
2/2000-2003 MONTERO ONLY.
*NOT FOR MONTERO SPORT*.
MITSUBISHI 6G74 5/1996-2004 ENGINE 6G74. SOHC. 24 VALVE.CAM AND CRANKSENSORS.
OIL FILTER MOUNTS TO OIL PUMP ON DRIVERS SIDE.
5/1996-2000 MONTERO
6/1998-2004 MONTERO SPORT.
I'm glad I found this information before I started. Phew...
Old Feb 12, 2018 | 04:20 PM
Thank you for posting the answer. This is one of those things, that unless you've done a ton of research or have completed similar project, you may not know the little details.
Question: Is change of oil filter location affects the engine fit in the engine bay? Is it possible to circumvent this problem by installing a remote oil filter?
Old Feb 12, 2018 | 05:14 PM
larry4406's Avatar
I think also the montero sport engine does not have a knock sensor.
Old Feb 12, 2018 | 05:38 PM
dahlelama's Avatar
From what I researched, its more than just the oil filter location. Crank endplay spacing and location of the cam position sensor are different as well. Those are just a couple that come to mind but those are big items.
Old Feb 13, 2018 | 02:01 PM
wilde's Avatar
Thanks for the answers. Too bad the leaders of the company didn't plan more modular motors for most of their fleet of cars. Would have been nice to be able to pull a motor from a half-dozen other makes and bolt them together.
Old Jul 22, 2018 | 10:16 AM
nipponpajero's Avatar
Just confirming. I can put a 2003 or 2004 Montero Sport 3.5 engine into a 2002 Montero Sport? Thanks
Old Jul 30, 2019 | 02:26 PM
codyatfixdrite's Avatar
Default Engine Swap Questions
I hope I am on the right thread, I am new here. I am about to embark on an engine swap. from 1996 montero 3.0 engine to a 2002 model montero 3.5 engine. I need to know if this is a compatible swap. The block and harness connections look to be the same, It looks to me like it should fit. Is there any reason this swap will not work? Any advise or modifications that I may need to be aware of? Any help is appreciated. Thanks.
Old Jul 30, 2019 | 10:23 PM
iXod's Avatar
Default Not sure if it will *fit*
The 2002 3.5L engine is listed as having 197 HP. The 1996 3.0L had 177 HP. That's significant difference. I think the final drive gear ratios (and who knows? maybe the trans gears too) may be significantly changed between those years and engines such that the 20 HP difference will make the driving experience... not pleasant.
iX
Old Aug 1, 2020 | 03:00 AM
Angel Salazar's Avatar
Im sorry but i dont quite understand but my question is can i swap the engine from a 1999 montero sport 3.5l engine to a 2000 montero sport ??
shownuff80
Aug 31, 2014 03:40 AM
dangallagher23
Mar 15, 2014 12:05 AM
importpreformance
May 3, 2009 08:06 PM
max3
Nov 27, 2007 05:08 PM
Offroad Monkey
Sep 18, 2003 03:55 AM
