Montero Sport Fuel System Diagram
Old Sep 21, 2013 | 09:38 PM
tero's Avatar
Default Montero Sport Fuel System Diagram
Is this correct?
Old Sep 23, 2013 | 07:13 AM
tero's Avatar
Can someone please verify on their Monty if D & E are correct. Thanks
Old Oct 3, 2013 | 02:24 PM
tero's Avatar
this forum is absolutely terrible... sorry just had to get that out of the way.
For anyone who cares, the diagram above is correct.
Also, I learned a 2001-2004 fuel pump assembly will fit an early 2000 MS. Everyone said it would not fit, but the pictures looked identical online so I ordered it and it was exact same part. Airtex made the pump #E8439H.
Your welcome
Old Oct 7, 2013 | 02:54 PM
tero's Avatar
before/after
Old Mar 30, 2017 | 01:34 AM
fikse's Avatar
I am into fixing my MS fueltank. These pictures and desription helped alot. Thank you
Old Sep 22, 2019 | 02:35 PM
Kprof's Avatar
Default Thanks for sharing this
I am the happy 2nd owner of a Montero xls sport i am replacing the filler neck and your diagram helps me if i do the complete fuel system thanks any more reference here is appreciated
Im in nj . Am getting ready for inspection and am anticipating all the details
Old Sep 24, 2019 | 01:33 PM
Kprof's Avatar
Default T
Does anyone know if this fuel tank is obsolete or not produced by any after market company a reply would be appreciated .
I did get the filler neck from Mitsubishi parts inc in Florida they were knowledgeable just need the last 8 digits of the vin .hopefully my post is a helpful contribution here .
My Montero xls was deceptively sold to me i will persevere through the repair its a nice vehicle . Thank you . Kprof
Old Sep 25, 2019 | 04:52 AM
larry4406's Avatar
Not sure of your year, but here is a link for a new OEM tank for a 2002 Montero Sport XLS, 2002 Mitsubishi Montero Sport Parts - Fuel Tank - MN120735, for $868.74. Says it includes the sending unit. I assume it does not include the pump
https://mitsubishiparts.com/2002-mit...MN120735-item/
Old Sep 25, 2019 | 05:00 AM
larry4406's Avatar
Here is a diagram from the manual. Hope this helps.
Old Nov 11, 2019 | 10:03 AM
Kprof's Avatar
Default Fuel tank
This is the tank from a 1999 monti sport xls feb 99 build date
I did this job its pretty easy to remove . I replaced the rubber lines with new my issues were with the connection to the fuel filter i kept having a leak its pretty scary it sits it runs pressure tests no leak then the next morning after a warm up and drive it spews out the repair fittings . Any help with this one is appreciated.
ExtremeHobo
May 5, 2016 09:15 PM
jazciel
May 29, 2014 01:10 AM
jallert
Jun 9, 2012 10:21 PM
fitenfire4life
Nov 13, 2011 08:49 PM
mieszkoj
Aug 10, 2005 04:24 PM
