Montero Sport TPS
Old May 27, 2008 | 10:43 AM
sammyboy02468's Avatar
Default Montero Sport TPS
Hello all. New to the forum here and just picked a 98 Montero Sport 3.0L a few months ago. It started having some idling issues. Idles pretty rough and sometimes the RPM's drop so much it shuts off. Eventually the CEL came on and I scanned it with a code reader. Code came back saying TPS sensor was closed. I am assuming the TPS is bad on the vehicle and I am going to go ahead and replace it. My question is, is the TPS on the 3.0L Montero Sport an adjustable TPS and how do you install it properly. I know it does involve and ohm meter hooked to the sensor then you adjust it till it reads the proper ohms correct? I have replaced a number of TPS sensors however none were adjustable.
Thanks guys
--Sam
Old Jun 22, 2008 | 12:21 PM
mxmikie's Avatar
Default RE: Montero Sport TPS
it is adjustable but it could also be your isc motor change the o ring on the biss screw .. i have a tps if you need one
Jeff H
May 31, 2010 10:14 AM
NGC1672
Mar 30, 2010 07:11 PM
Toshab68
Oct 12, 2009 11:16 AM
FARDJA
Jun 28, 2005 11:05 AM
Vetter
Nov 22, 2004 10:44 AM
