Need help accessing antenna motor
Old Jun 20, 2005 | 12:29 PM
SlowCat's Avatar
Default Need help accessing antenna motor
I have a 01 Sport Ltd and the mast would only go down with a little help tap from above. I took to Mitsu and they said a gear in the motor is bad, Now I get it back from them with the antenna in the down position and it wont go back up with no reception. I bought a new antenna off ebay thinking it shouldn't be to hard to do, but before taking stuff apart I was hoping someone might have a tip or two when doing this like accessing the motor assembly. HELP!!!!!
Old Jun 22, 2005 | 06:39 PM
fnfal's Avatar
Default RE: Need help accessing antenna motor
Since this is a generic problem I can be of some assistance. The gear in the motor is probably fine what happens in most cases is the Nylon runner in the mast becomes brittle and a portion of it breaks off in the motor causing the mast to raise but as the broken runner clears the gear it will not retract without being pushed down so the gear can engage. Normally the only way to remove the broken section is to pull the antenna motor, open it remove the broken runner, usually re-grease the gears while you are at it then remount the motor. You then feed the new runner into the motor during its normal retraction sequence and run it up and down a couple times to set it.
Old Jun 25, 2005 | 12:48 AM
SlowCat's Avatar
I thank you for your response but what I'm really looking for is how do I get the antenna motor out? Do I get to it from the wheel well or do I get it from the engine compartment?
Vadimus
Jun 12, 2023 10:01 PM
ddappete
Oct 19, 2013 02:04 PM
redturboeclipse
Oct 26, 2009 10:41 PM
Outlander_Joe
Dec 3, 2008 08:16 PM
InSane_KiD
Aug 29, 2008 10:55 PM
