Antenna Motor
Old Aug 27, 2008 | 01:14 PM
InSane_KiD's Avatar
Default Antenna Motor
The motor for my 95 3000gt antenna runs longer than it should when turning on and off the radio. It works fine but is a little annoying. The antenna will be fully extended but the motor runs for another 10 or so seconds. Any way to fix?
Old Aug 29, 2008 | 10:55 PM
HandyPal's Avatar
Default RE: Antenna Motor
If you're up to the challenge of taking it all apart and tinkering with it... the answer is "YES", you can do it. You need to find the limit switches in connection with the plastic gear and set it accordingly to the desired length of your antenna. It could be tricky though and much dependent on particular design. I would suggest leaving it alone 'till it fails and then replacing it all along with the new stuff.
Permanent antenna would be my choice.
ddappete
Oct 19, 2013 02:04 PM
redturboeclipse
Oct 26, 2009 10:41 PM
mitsubu
Oct 3, 2005 08:36 AM
SlowCat
Jun 25, 2005 12:48 AM
