Need pic of 01 Montero LTD under hood
Old Jan 13, 2014 | 08:25 PM
one iota's Avatar
Default Need pic of 01 Montero LTD under hood
or pic of intake plenum or shop manual diagram or something.
Near the end of October, I had taken my 01 Montero LTD to a shop because I couldn't figure out why truck was overheating and losing coolant. I'd have to fill the reservoir every day. Then for some reason, the reservoir was staying full. Still overheating and losing coolant, but now the radiator would be low while the reservoir stayed full.
Anyways, the shop hit me with a timing belt, water pump, coolant flush, fan clutch, and idler pulley bearing. $1600!
When I got my truck back, it squealed, clunked, and clicked in the dashboard, was still overheating, making gurgling sounds, wouldn't idle right in drive, and the induction tube for the air filter, the intake plenum, and other plastic beauty pieces were missing. The reservoir was empty, an engine hoist bracket was sitting, along with its bolt, on the top of the engine, and oil was dripping from the skid-plate.
My truck has been back there five or four times on re-do and everytime I get it back, there's something else wrong with it. OK, they did fix the squealing by replacing the other belt tensioner pulley ($200 which they ate); the clunking, by removing the prybar that was left by the firewall; the clicking, by removing another tool left in the dash; fixed the gurgling, by bleeding the air from the cooling system and drilling two holes in the thermostat. But now I don't have any heat in the cab. Well, the drivers side puts out a little heat, a little less in the middle and none on the passenger side. Go figure. It blows air, but no heat.
Old Jan 13, 2014 | 10:09 PM
Mr. Z.'s Avatar
Wow! I'm very sorry to hear about the issues you are having with your mechanic.
Here is a link to the FSM for the Gen. III Monteros with a 3.5L.
http://www.pajero4x4.ru/piii/
If I was in your shoes, that mechanic would not get another crack at the Monty.
Cut your loses, and take it to the dealer (or reliable mechanic) for a thorough run through.
Old May 28, 2014 | 08:03 PM
one iota's Avatar
Nobody has a stock '01 or '02 full-size Montero that you can just pop open the hood and take a pic for me?
Old May 28, 2014 | 08:31 PM
Mr. Z.'s Avatar
Here are a couple of snap shots...
Attached Thumbnails Need pic of 01 Montero LTD under hood-p5280137_2.jpg   Need pic of 01 Montero LTD under hood-p5280138_2.jpg
Old Jun 6, 2014 | 08:41 PM
one iota's Avatar
Hey Mr Z. Thanks.
Looks like your truck is missing the pieces that were removed from my truck and promptly lost.
Thanks also for the link to the FSM.
navidbe
Feb 22, 2014 08:46 PM
Eclipsor
Oct 15, 2006 09:51 PM
s_chev
Jan 18, 2006 04:38 PM
s_chev
Jan 16, 2006 06:44 PM
Black98
Apr 9, 2005 11:07 PM
