New Member 1994 Montero SR
Old Sep 18, 2011 | 12:18 PM
Motornuts's Avatar
Default New Member 1994 Montero SR
Recently picked up a 94 Montero, 140k miles. Previous owner was meticulous about maintenance and it is in very good shape for it's age. It does have two issues we would like to fix. First is the fog lights, we cannot locate the fuse or the relay for them and they do not work. Second is the cruise control does not work and appears that this may also be a fuse or relay. Neither the fog lights or the cruise control are listed in the manuals fuse section, and the markings on top of the engine box are worn off. Anybody know where to locate these items?
Thanks!
Old Sep 19, 2011 | 09:44 PM
Mr. Z.'s Avatar
I would recommend rewiring the lights if there is any question on the quality of work that went into the original set up. Using one of the extra slots in the fuse box (if possible) and your own relay and switch is not that expensive.
Check the cruise control section in your FSM on a place to start diagnosing the problem, see if it's throwing any codes.
Good Luck
Old Sep 19, 2011 | 11:09 PM
mxmikie's Avatar
get a manual
Old Sep 20, 2011 | 07:25 PM
Motornuts's Avatar
Default 94 Montero
As far as we can tell, the fog lights are factory installed. But I agree that re-wiring might be easier at this point. I am working on picking up a manual. Thanks for the replies.
Old Sep 20, 2011 | 08:25 PM
Mr. Z.'s Avatar
You can use a web based FSM until you get a paper version.
Here is a link to a Russian site with the FSM online:
Pajero 4x4 Off-Road Club 2000-2008
(Don't let the link title fool you, the site has your Gen. II manuel.)
Good Luck
mikewired
Aug 4, 2019 08:14 PM
Montezuma
17
Oct 7, 2010 05:36 PM
gwagon
May 12, 2008 06:14 PM
masond24
Oct 20, 2005 08:34 PM
ron Kirk
Jul 31, 2005 01:45 PM
