New member looking for a little help with a new engine.
Old Aug 10, 2010 | 08:40 PM
Challenger84's Avatar
Default New member looking for a little help with a new engine.
Hi everyone.
I'm a new member here.
I have a 95' Montero SR 3.5 with 113k
I'm in need of a replacement for my engine.
Does anyone know of a good place to find one?
Is it worth replacing?
I believe I spun a bearing.
the engine was over revved and started to sputter and died out.
I tried to start it back up and when the engine did fire up I heard a taping noise.
The fast the rpm are the faster the tapping noise.
Thanks everyone in advance for any help and advice.
Old Aug 11, 2010 | 07:35 PM
bump.
Anyone?
Old Aug 11, 2010 | 07:50 PM
jrmdir's Avatar
Are you having any other symptoms than the tapping noise? If it seems to run well, not smoke and has good oil pressure you should try this before deciding you need a new engine. The problem this fixes sounds very much like a serious engine knock.
http://www.4x4wire.com/mitsubishi/te.../lifter_noise/
Ron
Old Aug 11, 2010 | 10:40 PM
Thanks for the link Ron.
I'll go out and try it now.
I also live in the Bay area!
Old Aug 11, 2010 | 11:15 PM
WoooHOoooooo!!!!!!!!
Wow.
That link actually worked!!
I brought the Monty to my mechanic and he told me I had to replace the entire engine! What an A-hole,
He was gonna charge me $3500 for everything!
I owe you big time!!
Can I buy you a beer or something!
You just saved me $3500!!!!
Aahhhh I can't help but be excited!!
Now the engine is totally silent!
Sorry for all the "!" I'm too happy
Thanks again JRMDIR! Your a life saver!
btw My Monty looks justlike yours in your sig.
Same color and everythinig
Old Aug 12, 2010 | 05:52 PM
jrmdir's Avatar
Glad to help and even more glad you didn't get hosed for a new engine. When I first heard that noise I also thought the end had come. So it saved me big time as well - what goes around comes around.
BTW, I recently got a factory service manual and the procedure is written there exactly as in the post - so it's not junk science.
In my case the noise started because I let the oil level drop too low and went way too long between changes. Never again!
So keep it well lubed and enjoy driving it!
Ron
Old Aug 12, 2010 | 06:00 PM
jrmdir's Avatar
Oops, I just remembered - even with better attention to oil changes the noise did come back again - once. And the rev procedure fixed it right away once again. That was more than 50K miles ago so if it happens again don't be concerned.
Ron
Old Aug 12, 2010 | 09:06 PM
Yeah I just changed the oil today.
Now that I think of it I sea foamed the car before this happened.
I think the sea foam broke loose some sludge and gunk and probably got stuck it the valve thing.
I just got the truck and was doing major tune-up on her.
I'll be on top of all the oil changes.
I pulled my boat out today for some fun on the water and the Monty had no issues pulling the boat.
Thanks again for the help.
'm pretty handy when it comes to cars and boats.
I just need to get the manual for it.
Do you have a hard copy of the manual of do you have it as a PDF format?
If PDF then I would love to get a copy of it.
Old Aug 13, 2010 | 10:37 AM
jrmdir's Avatar
Mine's a hard copy and specific to the '99 model. There are some posts that talk about on-line versions so try the search function. Here's one that has some info but there are others.
https://mitsubishiforum.com/forum/sh...hlight=russian
Good luck!
Ron
Zequel
Dec 26, 2014 01:40 AM
MMueller408
Jan 20, 2014 04:55 AM
bk3939
Dec 10, 2007 02:09 PM
rpatillo
Dec 28, 2004 09:10 PM
rpatillo
Oct 12, 2004 10:32 PM
