noise from mastercylinder
Old Jun 21, 2007 | 06:45 AM
Oldhat's Avatar
Default noise from mastercylinder
Have a 2002 montero. I have a strange noise comming from the mastercylinder. When the brake pedel is pushed there is a noise like two quick churpes. usually when the pedal is realeased. The brakes work great, no problems. There are no brake warning lights.Any one had this problem. I do not want the brakes to fail when my wife is driving theMontero
Thank you
Old Jun 21, 2007 | 04:31 PM
Manybrews's Avatar
Default RE: noise from mastercylinder
sounds like a ruptured accumulator.
DONT try to fix it yourself. get it looked at soon.
Old Jun 22, 2007 | 06:23 AM
Oldhat's Avatar
I am taking it to the dealer on monday to have it checked out . Will let you know.
oldhat.
Old Jul 29, 2007 | 03:52 PM
vwscrub's Avatar
I have the same problem and am interested in finding out what the dealer told you about your system.
Thanks
Old Aug 24, 2007 | 01:05 PM
jarrietv's Avatar
I'm also having the same problem on my 02 Montero Limited. sounds like a have a freaking bird under the hood! Please let me know what you find. I took mine to a local shop (not Mitsubishi) and they couldn't determine the problem, they told me to replace my rear pads/turn rotors, and I had a heat crack in my left Fr. rotor. I did everything they suggested and the sound's still there, I knew it would be but I needed to replace the pads and Fr. rotor anyhow so I figured what the heck... I thought maybe it was something with the ABS computer??? I'm going to hook up some DTC software this afternoon to see if it's throwing out any error codes.
Old Aug 25, 2007 | 08:53 AM
Manybrews's Avatar
ORIGINAL: jarrietv
do people here actually bother READING the posts?
ive already said what it is and what to do about it. if you're not going to read, why bother posting?
Old Jun 25, 2021 | 06:05 AM
mmhunt41's Avatar
Thank you
could be an airlock in the break fluid. Change fluid
Old Jun 28, 2021 | 09:43 PM
Nope. Air in the brake lines will result in a soft pedal feel and poor brake performance. As described, the symptoms are 100% those of a failed accumulator. Pretty easy repair.
Old Jun 28, 2021 | 10:28 PM
mmhunt41's Avatar
Default Pajero
Thankyou for your input. Now that you have mentioned that a soft pedal ( which I haven’t got) is the result of an air lock, I’m inclined to agree that it is a problem with the accumulator. Thanks again.
Old Jul 6, 2021 | 09:51 PM
mmhunt41's Avatar
Default Pajero
Pajero.
turned out to be a faulty a faulty ABS module.
got a new one fitted and all is well by Mitsubishi
but expensive.
cdvyas20
Sep 20, 2020 01:53 PM
helicopterred
Jan 14, 2019 11:49 PM
yvds10
Jun 24, 2014 04:35 AM
GIO_2.O
Apr 10, 2009 07:33 AM
masterxox
11
Mar 25, 2008 09:34 PM
