Oxygen Sensor Questions
Old Apr 19, 2007 | 01:32 PM
mrtoyman's Avatar
Default Oxygen Sensor Questions
Hi All,
I'm new to the forum and have to say i love it so far. It is very informative and friendly one.
Yesterday, i finally got the chance toscanthe "Service Engine Soon " on my 2003 Montero Sport Limited with a 3.5L engine and i believe all i got are four are errors for my O2 sensors and they are as folows;
1 of 4 - PO161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
2 of 4 - PO141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
3 of 4 PO161 O2 Sensor Heater Circuit Malfunction (Bank2 Sensor 2)
4 of 4 PO141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
I'm i correct in assuming that i need to replace all Four(4) of my O2 Sensors and that there is actually 4 units that i need to replace. Can you also please let me know the exact location of these sensors(tried searching and can't seem to find an answers). I am the first owner and i know for a fact that none of these have been replaced.
In addition, I also read about a TSB with regards to "Diesel Engine Sound" when the truck is on idle, Will the dealer be able to eliminate this sound if i bring to them for service and is this still covered by the warranty.
I apolgize if i asked too much for a first timer but i really like to bring my truck into shape.
Thanks.
Old Apr 19, 2007 | 02:51 PM
off roader's Avatar
Default RE: Oxygen Sensor Questions
If it's still under warranty, then I would doublecheck the terms of your warranty. I'd expect both problems to be covered.
Old Mar 20, 2012 | 12:00 PM
gewaddy's Avatar
Default 2001 Diamante bank 2 sensor 2 plug location
I'm trying my best to locate the 4 pin plug that terminates O2 sensor on passenger side aft; (bank 2 sensor 2)-- the Mits. dealer parts diagram is totally useless for location... Can anyone help?!?
Thanks, gewaddy
Old Mar 20, 2012 | 01:40 PM
sevendogzero's Avatar
Default o2 Sensors
I have two Mitsubishi's.
2004 Endeavor
2003 Montero Limited
It sounds odd, that all your sensors are out, but I have replaced 2 on my
cars.
First off, most dealers and parts people DO NOT know which sensor is which.
On my Endeavor, since the engine is mounted sideways, every "expert" was
seemed confused about which Bank was which.
Here's my advice.
Take an O2 sensor off. The easiest one.
You may need a special socket. I got mine at PEP Boys. The one I bought at AutoZone didn't work with the Bosh replacement sensor they sold me.
Bring your socket with you if you have one, or test the one you buy with the
sensor you buy!
Replace the sensor.
You will need to drive the car around 10-20 minutes.
The have re-scan the codes. You should have one less Error Code.
If so, pretty good chance all your sensors are bad.
This is my experience
Old Mar 26, 2012 | 10:47 AM
mvious's Avatar
Umm, aren't there only two bad ones, look closely. Bank 2 sensor 2 and Bank 1 sensor 2, the codes are repeated!
Old Mar 17, 2014 | 02:17 PM
evelina1's Avatar
o2 senor code p0155 2004 Mitsubishi Endeavor need to be replaced I can work on cars. can someone please send me a picture of the area of where I can find and replace the sensor? thank you
Last edited by evelina1; Mar 17, 2014 at 02:22 PM. Reason: did not give enough information
mrbo
Jan 4, 2015 09:52 AM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
majordomo
Apr 20, 2006 01:28 PM
Crispious
Jul 23, 2005 09:11 PM
