PG Assembly Malfunction on Montero
Old Sep 14, 2007 | 07:11 PM
foolane's Avatar
Default PG Assembly Malfunction on Montero
Get DTC Code P1715 - PG Assembly malfunction! What does this mean? Is my transmission cooked or is it just an Electronics issue?Should I just reset it? Please advise. Thanks a lot! The Freeze frame info is below. If I clear it, what happens next?
OBD2 Diagnostic Report
Freeze Frame
Parameter Description Value
DTC for which Freeze Frame was Stored P1715
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 25.10 %
Engine Coolant Temp 195.80 °F
Short Term Fuel Trim - Bank 1 7.03 %
Long Term Fuel Trim - Bank 1 4.69 %
Short Term Fuel Trim - Bank 2 5.47 %
Long Term Fuel Trim - Bank 2 5.47 %
Engine RPM 675 rpm
Vehicle Speed Sensor 2.49 mph
Report# 1 /Date: 9-12-2007
Old Sep 15, 2007 | 10:02 AM
Manybrews's Avatar
Default RE: PG Assembly Malfunction on Montero
you CANNOT use the PCM code to properly diagnose trans issues. The code is a generic code, not applying to the actual problem.
you need to access the trans computer to properly begin diagnosing.
Old Sep 17, 2007 | 01:23 PM
off roader's Avatar
Also year and model of Montero would be nice to know.
Old Sep 22, 2007 | 06:59 PM
foolane's Avatar
1997 Montero LS
Old May 14, 2013 | 05:59 PM
Richigo07's Avatar
I got the long term fuel trim bank2 stuck the line goes –------------------ dont do nothing what can i do?montero limited 2001
Old May 14, 2013 | 06:16 PM
Your post makes no sense. Start by making a thread, and typing in coherent sentences.
newyorkmitsu
May 10, 2017 11:20 AM
tdennehy
Oct 23, 2014 12:35 AM
Sparkmdb
May 2, 2011 06:46 PM
ann
Jul 19, 2010 09:50 PM
bkcoburn
Feb 15, 2008 09:23 AM
