Piston Position for TDC
Old May 12, 2024 | 02:03 AM
Serviceman's Avatar
Default Piston Position for TDC
Hi Guys
I have a 2006 NP pajero with a 3.8L engine
Timing belt snapped off
Taken the heads off for a rebuild ( suspect belt valves? )
With the heads of, I rotate the engine to align the crank timing, yet piston 1 is down
2 and 5 are up.
Just need confirmation this is correct
Keep in mind the belt snapped so I'm starting from scratch......
Old May 14, 2024 | 01:00 AM
That is not the timing mark. If you remove the crankshaft pulley, you'll see the dot imprinted on the front of one of the teeth. That is the proper mark
Old May 14, 2024 | 01:20 AM
Serviceman's Avatar
Default Thanks for the reply.
glad u pointed this out. Appreciate the reply.
Careful
Sep 15, 2017 08:36 PM
myoung2746
Jan 12, 2014 12:31 AM
ccernst
Jan 7, 2012 01:13 PM
AWorthington
Mar 21, 2011 12:56 AM
