Purchasing a used 3.0 from wrecking yard?
Old Sep 7, 2015 | 02:42 PM
PalmSprings's Avatar
Default Purchasing a used 3.0 from wrecking yard?
Im considering getting a 2000-2003
3.0 engine from a wrecking yard and putting it in the m/s whos engine dumped .
I plan on driving it 50-100K miles over the next 5 or 10 years.
That means Im going to have to locate an engine with 100k approx
Since CR of each cylinder is all I'll know about the engine
,how can i use mileage and CR to guestimate how long it should last. Remember,this is all the info I can know before deciding to purchase it.
BTW what is the CR new?
Old Sep 9, 2015 | 10:07 PM
I don't think you can accurately estimate (or gestimate) engine mileage based on compression ratio. It will all depend how well services were performed on the engine, if the engine was run constantly at high RPM, towing, etc. If you can open up the drain pan and valve covers - look at the condition of the bottom and top end of the engine. Getting a used engine from a wrecking yard is like buying a cat in a bag, but sometimes that is the only option and you may get lucky too.
Rotarial
Sep 23, 2011 10:20 PM
YonkersMitsuJoe
Jul 6, 2006 03:27 PM
305RS97
Feb 13, 2006 10:59 PM
amo
Jun 13, 2005 06:14 PM
chitowns4
Jan 12, 2005 06:54 AM
