Question on Headlamps being too bright
Old Jan 23, 2007 | 09:39 PM
nvpurk's Avatar
Default Question on Headlamps being too bright
I have a 2003 Montero Sport Limited, and I'm always getting "flashed" at night because oncoming cars think I have my High-beams on. Is this something that needs to be remedied an authorized serviceman, or is there some way to lower the angle of the low-beams? [I looked at the headlamp mechanism, and I can't see any way to adjust the lights.]
It really appears the previous owner put in very bright lights for the low-beams, so I just might have to replace the bulbs -- the low-beams seem to be much brighter than the high-beams!
Thanks for any suggestions.
Scott
Old Jan 23, 2007 | 11:03 PM
off roader's Avatar
Default RE: Question on Headlamps being too bright
ALL headlight systems are adjustable these days. In some systems there's a **** you can turn to adjust aim and in other cases there's a screw at the top and the side of the headlight assembly. My gen I has screws. Check for these on yours.
Old Jan 24, 2007 | 01:05 AM
nvpurk's Avatar
I can't see any adjustment screws or *****. I had a friend look and he couldn't see anything. Looks like I'll have to take it to the local dealer....
Old Jan 24, 2007 | 02:37 AM
Rumplecat's Avatar
Is it a dual beam or a single?
Old Jan 24, 2007 | 04:17 AM
Joel_CA's Avatar
There a
Old Feb 18, 2007 | 12:26 PM
ichudi's Avatar
I had that problem when I first got my 2003 M. Sport XLS, I just adjusted the headlights down a little bit, and haven't had a flasher since. I still get more than enough light coverage on the road ahead of me, even with low beams. These were the original equipment headlamps too.
puddy
Mar 20, 2023 09:25 AM
armymen
Aug 5, 2010 05:30 PM
abrcrombe
Feb 3, 2008 03:31 PM
Blue Sky
Jul 23, 2007 09:27 AM
albert
Apr 4, 2006 09:25 PM
