Replacing torque converter clutch solenoid
Old May 27, 2014 | 10:11 PM
Dhanu's Avatar
Default Replacing torque converter clutch solenoid
Hi,
My 2002 Montero 4WD vibrate when I'm going around 50mph and it stops as soon as I take off my foot off the gas paddle.
I showed it to my mechanic and his diagnostic is to replace the torque converter clutch solenoid.
Any thoughts on the diagnostic?
None of the local part stores (autozone, napa, oriely) got the part. Any idea on where to find the part?
Thanks.
Old May 28, 2014 | 06:54 AM
user 27474884's Avatar
You might find this thread helpful.
https://mitsubishiforum.com/forum/mi...shudder-33655/
Heres the part from rockauto, but I would see what the price is through the dealer as well.
2002 MITSUBISHI MONTERO Torque Converter
Hope this helps
Old May 28, 2014 | 10:14 AM
Dhanu's Avatar
Hope this helps
Thanks for the reply.
The RockAuto link you provided is for the Torque Converter. I'm looking for the torque converter solenoid. Is that a part inside the Torque Converter?
Old May 28, 2014 | 07:01 PM
maco35's Avatar
Check your drive shaft U joints first, also disconnect rear drive shaft and engage 4x4 and drive on the freeway and see if vibration is still there.... Just another idea.
Old May 28, 2014 | 08:37 PM
Mr. Z.'s Avatar
The most common reason for transmission shudder is using AFT that is not from Mitsubishi Motors. If you have not already done so, do a complete AFT exchange/flush (not a drain and fill).
Old Jun 2, 2014 | 10:26 AM
Dhanu's Avatar
Thanks for the replies.
newyorkmitsu
May 10, 2017 11:20 AM
badbowtie73
Jun 20, 2007 05:57 PM
UCYIBD1
Dec 4, 2006 10:57 AM
iceman
Jan 24, 2006 12:13 PM
ajsdad
Oct 11, 2005 09:03 PM
