SES for Oxygen Sensor
Old May 8, 2012 | 08:09 AM
auds02's Avatar
Default SES for Oxygen Sensor
Hi to all!
The SES light on my 2003 Montero with 75,000 miles on it was intermittently coming on and off. I went to autoZone and the code was P0155.
P0155 defined as Heated Oxygen Sensor- Bank 2 Sensor 1 (H02S21) heater performance
Probable cause:
1. Open or short circuit condition
2. Poor electrical connection
3. Faulty H02S21 (Bank 2 Sensor 1)
There were 2 sensors (right and left) before the Cat, and 2 sensors (right and left) after the catalytic converter. I just want to make sure which one is which before I order the part.
The dealer quoted me $450.00 + tax parts and labor.
Is there a DIY on how to change the heated O2 sensor? Thank you!
Old May 9, 2012 | 10:33 AM
WalkerTech's Avatar
AudsO2, I am a product specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. You can most certainly change out the sensor yourself. All that you should need is the new part and an oxygen sensor socket (22 mm). In some cases a 7/8 wrench will work. The link below will lead you to instructions on how to determine which sensor is Bank 2, Sensor 1 (pre-cat sensor). Make sure to get the direct fit part for your vehicle, as it will plug right in to the old connector. Follow the wire on your old sensor to find the connector. Should be a piece of cake. If you plan on ordering the part online, the parts finder on our homepage, or any other manufacturer’s homepage, can lead you to the right part number. Oxygen Sensor Catalog 2012
Old May 10, 2012 | 09:11 AM
auds02's Avatar
Hi WalkerTech,
Thank you so much for the reply!
Old May 10, 2012 | 10:29 PM
auds02's Avatar
Hi to all!
According to WalkerTech's Catalog, Bank 2 is located in the Driver's side and Bank 1 on the pasenger side. But when I check the part # it says only left and right. Is left side the same as bank 2 or driver side and right is bank 1 or passenger side?
Old May 14, 2012 | 09:47 AM
WalkerTech's Avatar
AudsO2,
Left or right is determined in relation to the rear of the engine. The side of the engine on your left if you were standing at the back of the engine (the side with pulleys is always the front) contains the left sensor bank.
Check out this page of our 2012 O2 Catalog for visuals: Oxygen Sensor Catalog 2012
I hope this helps.
mrbo
Jan 4, 2015 09:52 AM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
majordomo
Apr 20, 2006 01:28 PM
Crispious
Jul 23, 2005 09:11 PM
