Spare tire cover removal
My first Montero post! Just bought a high mileage 2005 Montero. I looked in the owner manual, but it wasn't helpful. How do I remove the hard plastic spare tire cover? I pulled on some plastic spring-loaded pins at the bottom of the cover and tugged on the bottom. It releases a few inches and then stops. I am reluctant to pull to hard since I'm sure I will break something. Does it just pivot up or is there some hidden latch somewhere? I've only owned it 2 days and don't want to break the cover.
Thanks,
Richard
Thanks,
Richard
You are on the right track. Pull out spring loaded pins (I'm amazed your '05 still has them), then grab the wheel cover by the bottom edge and pull straight out. It will slip off the wheel. The cover is designed to hook on the top of the bracket to stay in place. It will only come off when you move the bottom past the tire and you can tilt the cover forward.
I find it is easier to do this when the trunk door is open all the way. That way you can get a better grip on the cover and see which way it is going.
HunterD,
Thanks for the response. It was really stuck in place, but I convinced it to come off. The tire under the cover looked new--but very old. I think the rubber had bonded with the tire cover.
Thanks again,
Richard
Thanks again,
Richard
Hello- I searched and found your post regarding removal of the hard shell spare tire cover. When I purchased my 2003 the cover was missing. I ordered the fasteners from a Mitsubishi dealer.
The kit had two spring loaded fasteners, two clips that mount on the base of the cover mount attached to the vehicle.
OK, the mechanics seems straightforward,however they have sent me two plastic washers too.
well the head on the spring fasteners has two barbs which you obviously turn to lock into the female clip on the car.
But the hole on the washer is to small to attach to the ****** spring tensioner.
Does anyone know were these go.
Thanks for your help.
deltadawn
Oct 1, 2012 08:06 PM
tsheahen
May 6, 2008 06:29 PM
bugmenot
May 3, 2008 12:56 PM
