speedometer not returning to zero
Old Jul 23, 2010 | 02:14 AM
gaz42's Avatar
Default speedometer not returning to zero
Hi - I'm a new member of the forum, located in Australia. I drive an '02 NM Montero (Pajero here). Because it seems that my instrument lights aren't a bright as they were, I removed the instrument cluster to check the bulbs - this also included dismounting the white plastic pcb on the rear to see if there were bulbs underneath. As it turned out the problem is probably more ageing eyes than fading bulbs.
HOWEVER since I've replaced everything I have noticed that the speedo doesn't return to zero (stops at probably <5) and when starting off it moves only slightly till it jumps to about 20 km/h (about 12 mph) and then all is good. It is as accurate as previously when checked against the GPS.
Has anyone else experienced this, and if so is there an easy, quick and cheap solution?
Gaz
Old Aug 1, 2010 | 10:05 PM
gaz42's Avatar
I found the answer to my question above when I looked on the Pajero Owners Club of South Africa forum - here's the link
http://www.pajeroclub.co.za/forum/vi...hp?f=27&t=1075
The process is quite simple, and probably worth noting for any other members who need to remove and replace their instrument cluster and particularly the PCB on the back.
Fixed my speedo in about 10 minutes all up!
Thanks to SA Forum member Goldmember!
Gaz
new_kid
Jan 17, 2011 04:34 PM
mrvr2007
Jan 20, 2009 11:27 AM
studnet100
Oct 18, 2006 05:02 AM
Koobs
Mar 14, 2005 02:34 PM
xtrm
Sep 29, 2004 10:26 AM
