Stripped crosmember bolts anybody ever had this problem ?
Old Feb 10, 2018 | 02:47 PM
Randy Otter's Avatar
Default Stripped crosmember bolts anybody ever had this problem ?
So my 02 montero limited had this vibration around 2400rpm and I found online it could be the rubber bushings on the crossmember so I bought them and replaced them but I found out the 2 bolts on the driver side were stripped out soon as I removed them has anybody else had this issue ? What did u do to fix it ? I had to drill through my floor board to get access to put a nut on the end of a long bolt but now it seems as if the vibration is a lot worse because I had to do that do these crossmember bolts have to be at a certain length to not vibrate ? Is tightening them all the way down causeing this ? Any ideas woukd be fantastic
dlx_11
Nov 23, 2012 09:48 AM
BrunoBoy650
Oct 3, 2008 06:19 PM
rcpax
Sep 18, 2008 04:15 PM
jpmontero98
Oct 3, 2007 03:39 PM
cagedruss
Aug 31, 2006 08:58 PM
