time to flush the trans, any oil suggestions?
Old Nov 25, 2010 | 09:57 AM
ourlee's Avatar
Default time to flush the trans, any oil suggestions?
i bought two waverunners and i'm going to tow them with my 01 xls with 160K on the odometer.
I'm going to change all the fluids, so i need suggestions for:
trans oil?
diff oil?
brake fluid?
thanks for your help, is any of these mitsubishi only or can they all be substituted? will it hurt to change to synthetic at this point in the game with 160K?
Thanks, Rick
Old Nov 26, 2010 | 12:44 PM
Mr. Z.'s Avatar
I use OEM tranny fluid.
Amsoil in the gear box and diffs,
and standard DOT 3 or 4 for the brakes.
Good Luck
Old Nov 26, 2010 | 06:21 PM
FireDoc's Avatar
Just make sure that if you change brake fluid dot3 to 4, that you bleed the entire system. your pedal will go to the floor otherwise.
amstafford
Oct 9, 2009 02:26 PM
rodriguez2432
Jan 28, 2009 05:34 PM
RonP
4th Generation
Feb 14, 2008 05:04 PM
antox18
Nov 11, 2006 11:14 PM
Prophet
Aug 6, 2004 07:22 PM
