timing belt
Old Mar 30, 2005 | 11:15 PM
NewYorkMontero's Avatar
Default timing belt
is there anyone from new york city who can direct me to a place other than dealer to do this job dealer gave me quote that made my jaw drop
Old Apr 1, 2005 | 07:40 PM
Winshawn's Avatar
Default RE: timing belt
Unfortunately, it is a big job to change the timing belt on these cars. You have to remove the, radiator, all of your accessory belts, air conditioning compressor, crank pulley, etc. Even if you are good it takes a long time. While you are in there you may want to consider replacing the water pump since the timing belt needs to come off to replace it. How many miles on your car? Dark Man will kill me but unless you have a DOHC the belt will last much longer than the 60k suggested replacement time. I waited 'till 90k but then I did my water pump, idler pulleys and belt tensioner. I also replaced all my accessory belts(cheap) and the radiator hoses and the radiator thermostat. Once you have it apart you might as well replace all that stuff. You should also consider the age of your car not just the mileage. If it is more than 6-7 years old it is probably time to replace it.
Old Feb 9, 2006 | 11:05 PM
TRUOMEGA's Avatar
go to shea stadium. Theres a junk yard there. U have many choices but i usualy only go to a mechanic named alfanzo. Name of the shop is "alfonso" located on 38th ave if i recall correctly. I have had other cars and my friends cars timing belts replaced there with no problems and great prices. I realize u think junk yard u think junk work. The place may not be clean, however, there r mechanics there that have been in business for 10+ years. Good luck.
Old Feb 12, 2006 | 08:08 PM
off roader's Avatar
New York Montero,
The details of what engine you have would be helpful!
Replacing the timing belt is a major job and literally requires removing almost EVERYTHING from the front of the montero to access the belt.
While you're doing the timing belt, I highly recommend also replacing your other belts, belt tensioners, pulleys/bearings, waterpump, etc.
judien
Mar 9, 2018 03:41 PM
marx88
Jun 30, 2011 03:54 PM
8000RPMS
Aug 30, 2007 05:49 AM
agallardo
Oct 29, 2006 11:33 AM
shawnharper
Jan 31, 2005 03:30 PM
