Transfer case and diff fluids
Did the 2002 full size Montero come with standard or synthetic fluid in the transfer case and diff's? I want to change now and can't find this info.
Mineral oils with additives for transfer case and rear LSD.
Mineral oil for front and rear non-LSD.
If you are doing this yourself please read the following to ensure you are aware of the SAE J306 Specifications changes affecting SAE 90 fluids.
http://www.lubrizol.com/DrivelineAdd...fications.html
I am running Amsoil 80W-90 in both diffs. The LSD has performed perfectly without any additives.
For the transfer case, I chose the Amsoil Severe Gear 75W-80. Gear selection is smoother and has less lag time than ever before.
Good Luck
Good Luck
mrlimey
Jan 26, 2018 11:12 PM
