Transfer case and diff fluids
Old Feb 26, 2011 | 12:41 PM
7-UP BILL's Avatar
Default Transfer case and diff fluids
Did the 2002 full size Montero come with standard or synthetic fluid in the transfer case and diff's? I want to change now and can't find this info.
Old Feb 27, 2011 | 08:41 PM
mitsustigi's Avatar
Mineral oils with additives for transfer case and rear LSD.
Mineral oil for front and rear non-LSD.
If you are doing this yourself please read the following to ensure you are aware of the SAE J306 Specifications changes affecting SAE 90 fluids.
http://www.lubrizol.com/DrivelineAdd...fications.html
Old Feb 27, 2011 | 09:35 PM
Mr. Z.'s Avatar
I am running Amsoil 80W-90 in both diffs. The LSD has performed perfectly without any additives.
For the transfer case, I chose the Amsoil Severe Gear 75W-80. Gear selection is smoother and has less lag time than ever before.
Good Luck
Old Feb 28, 2011 | 06:31 PM
7-UP BILL's Avatar
Thanks everyone. I've been an Amsoil guy for 25 years and was considering that for the change. Mr. Z, you helped make my decision for me. Thanks.
Old May 14, 2020 | 08:56 PM
Gene's Avatar
where is the fill plug on front gear case any pics
Old May 15, 2020 | 12:45 AM
Full size Montero has a big plug (hex bolt) on the front side of the front differential. That is fill plug and level indicator. Drain plug is on the very bottom.
Old May 15, 2020 | 11:33 AM
Gene's Avatar
Its the transfer case big hex underneath driver side suspension bar running right in front of it,so fill plug is?
Old May 15, 2020 | 12:43 PM
Gene's Avatar
The big hex bolt is on the very bottom but on the side facing out on driver side ,where is the fill plug relative to that position?
Old May 23, 2020 | 05:33 PM
Gene's Avatar
Is the same oil in front and rear differentials
Turbo351
Mar 7, 2025 04:07 PM
tcp
Oct 13, 2020 12:10 PM
mrlimey
Jan 26, 2018 11:12 PM
