Transmission fluid line disconnect
Old Oct 7, 2010 | 07:08 AM
MitJsus's Avatar
Default Transmission fluid line disconnect
Which line do you disconnect to flush the old transmission fluid out on a 2000 Montero Sport 3.0? I planning to change mine this weekend. Thanks.
Old Oct 7, 2010 | 05:39 PM
Mr. Z.'s Avatar
Here is a link to the FSM for the full size Monty (NM) tranny flush.
If your rig has a tranny cooler it's most likely very similar.
http://www.pajero4x4.ru/piii/GR00006000-23Aa.pdf
Check the following link to see if your set up is the same:
Good Luck
newoutlanderfan
May 27, 2013 10:47 AM
BelizeMike
Apr 12, 2013 12:44 AM
circlek
May 7, 2011 11:08 AM
jcasaccio
Jun 6, 2006 06:14 PM
glennsafrit
Oct 25, 2004 12:29 PM
