Using Oil
Old Nov 15, 2007 | 01:36 PM
tank's Avatar
Default Using Oil
I have an 02 Montero sport with 39k miles.
Over the last 3k miles I've gone thru 3 quarts of oil. one quart every 1k miles.
There's no blue smoke coming out of the backpipe.
The car runs fine. It never used oil before.
Anyone know what might be the problem?
I have a 3.0liter gasoline engine.
Old Nov 15, 2007 | 02:17 PM
Default RE: Using Oil
What kind of oil?
Old Nov 15, 2007 | 03:15 PM
jpmontero98's Avatar
check for leaks under the car and on the side of the block near the trans...i had a tiny oil leak there in my montero
Old Nov 15, 2007 | 05:45 PM
carlover626's Avatar
ORIGINAL: jpmontero98
Yeahcheck for leaksand do so after driving it warm for a while. I currently have a slow leak that isleaking onto my skidpate...but it doesn'tdripon the groundovernight. I have read that it could be the cam seal O-rings, but I have not taken it in as of yet.
JP, what was the culprit for you?
Old Nov 17, 2007 | 07:37 PM
tank's Avatar
Its engine oil. Nothing drips into the skid pan. Will check for leaks near the tranny, if it there's none..... I guess the cam seal o rings maybe next.
Old Nov 17, 2007 | 07:39 PM
I meant like conventional or synthetic?
Old Nov 19, 2007 | 11:00 AM
off roader's Avatar
Does it smoke alot during start up and after idling for a while? Have you ever had the valves done?
One of the problems with the 3.0L (SOHC or DOHC) engine is valve guide seal wear after 50-100k miles. I wouldn't be surprised if this is what your engine oil loss is from. If you do have this problem, you can R&R the valve guide seals w/out doing a valve job and it requires using either the rope through the spark plug hole trick or the LP Air the the spark plug hole trick. This involves removing the upper part of the engine to expose just the valve tops and the seals. You use the rope or LP air to keep the valve from falling into the cylinder while you remove the rockers then R&R the seals.
HTH.
Old Nov 19, 2007 | 05:48 PM
tank's Avatar
Its using synthetic oil
Old Nov 19, 2007 | 05:53 PM
tank's Avatar
Offroader, It never smokes....and there's no oil residue on the backpipe....
Old Nov 19, 2007 | 09:29 PM
ORIGINAL: carlover626
Yeah check for leaks and do so after driving it warm for a while. I currently have a slow leak that is leaking onto my skidpate...but it doesn't drip on the ground overnight. I have read that it could be the cam seal O-rings, but I have not taken it in as of yet.
still unknow...after i cleaned it up it didnt come back untill after 3 weeks....head gaskets were good...i gotta take a good look
Rick Brewster
Mar 10, 2015 02:08 AM
SERPENTOR
Dec 20, 2010 06:51 PM
jpclamme
Feb 6, 2008 02:47 PM
mossburg44
Aug 16, 2006 01:52 PM
pc
Jul 10, 2005 11:31 PM
