Will turn over but wont start
Old Sep 13, 2016 | 05:16 AM
Monteroman1994sr's Avatar
Default Will turn over but wont start
Hi i have a 1994 montero sr amd an endeavor but i hooked up the jumper cables backwards and then it wouldnt do anything cause the battery was old and kinda shot so i have a brand new battery and i try to start it and it just turns over wont start.and mind you ot has sat for a couple years but all the dash lights come on basically everything is as it should be but it just wont start I've put fresh gas in it and nothing changes ive checked all the fuses.and the.fusable links therebwas a few that were bad but i have replaced them and they were interior fuses that had nothing to do with the engine any ways thank you for your time and if you guys could give me some advice or know whats going on please let me know thank you and have a nice day
Old Sep 13, 2016 | 07:11 AM
The Silent Seed's Avatar
Sitting for a while = clogged fuel lines / fuel pump???? Just what came to mind first. Or even a clogged exhaust.
Old Sep 13, 2016 | 07:29 AM
Default good thinking
but you can smell the gas after cranking on it for a while but ill still check it out thanks for the advise
Old Sep 14, 2016 | 09:26 PM
If you can smell gas after cranking, then check if you are getting spark. You need both to make engine run.
Old Sep 23, 2016 | 10:04 PM
theshyguy's Avatar
Any luck since you last posted?
You said you put fresh gas in but the gas in the lines is still old unless you bled the lines.
Old Sep 23, 2016 | 11:57 PM
Hi sorry been busy with some personal stuff so haven't been on here or wrenching on the monty but im going to get.back on it in a couple days thanks.for all the good advice
pauhana3
Feb 5, 2014 10:46 PM
Sk8eR_PR
Jan 12, 2014 01:51 PM
tl1234
Oct 27, 2010 12:52 PM
ashulee12
Oct 21, 2008 04:22 AM
jcaswa123
Mar 10, 2006 09:50 PM
